Help with Painted Wood Siding
  • Help with Painted Wood Siding
    I'm trying to create a realistic painted wood siding texture. I made a texture that is okay, but it isn't as realistic as I would like. I added a wood texture normal map to the bump. And then I used a color, no diffuse bitmap, in the diffuse. Does anyone have a better way to create this material? I've attached my texture as well as an example of what I'm looking for.
Name:	PAINTED WOOD 1.png
ID:	1166085 Click image for larger version
    Hi calvin-ode
    As a advice dont forget to play with dirt textures, your wall looks like it was painted today, this kind of material needs a bit dirt textures since is outside, play with composite operator with miltiply Mode.
    I hope It helps.
    Also it looks too glossy... it should look a bit more desaturated and a bit matte reflections.
      Hi calvin_ode​,
      Your texture actually looks pretty good.
      Using a color instead of a diffuse map is the correct thing to do here.
      The materal that you're after is defined mainly by its bumpiness and reflectivity.
      I actually believe that your material will look similar to the ref in the right lighting conditions.
      Konstantin
