Is the Reinhard blend value of 0-1 in vray's color map management in 3DS max a parameter and the highlight blend in sketchup's vray?
  • Is the Reinhard blend value of 0-1 in vray's color map management in 3DS max a parameter and the highlight blend in sketchup's vray?
    在 3DS max 中 vray 的色彩映射表管理中,0-1 的 Reinhard 混合值是一个参数,而 sketchup 的 vray 中的高光混合值是一个参数吗?
    Hi cq_x​,
    The Highlight Burn parameter in SketchUp corresponds to the Burn value (Reinhard) in 3ds Max.
    Also note that the Reinhard color mapping mode is always used in SketchUp.
    Konstantin
