Vray 6 Sketchup Invisible Material Casting Shadow
  • Vray 6 Sketchup Invisible Material Casting Shadow
    Greetings,
    I will deeply appreciate any hammer-way guidance to get an invisible material that casts shadows. Alas, cannot find the suggested option (older version of Vray fo SU) - Material Options - Only in Secondary.
    Apparently any generic material can be used with some option to be invisible to the render.
    Many thanks in advance.
    simply add a "Raytrace Properties" attribute and uncheck the "Visible to Camera" option.
    Windows 10 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
    Sketchup PRO 24.0.594 + V-Ray 7.00.01
    3DS Max 2024.2.7 + V-Ray 6.20.06
    3DS Max 2025.3 + V-Ray 7.00.04
    Chaos Vantage 2.7
    GeForce Studio Ready Driver Version 566.14​
      Hello artur_chojnacki,
      What DCHA34 suggests is correct, please try it out and let us know if this is the result you need.
      Natalia Gruzdova | chaos.com
        Thank you very much for your prompt return.
        Alas I cannot (a problem between the chair and the screen?) reproduce the shown effect.
        Here are the results here with the pointed material setting. I will be thankful for the elucidation, if any. Click image for larger version
          Oh, I see... I have just applied in Sketchup the same material to both sides of the cube and made it disappeared!
          Is there within Vray material option - double side, or sth similar to be checked instead of applying it within Sketchup?
          Once more many thanks.
            Easiest way in this case would be to make a Component and apply material to the whole object.
            I have attached my test scene if that helps.
            Raytracing_properties_v6.zip
              Oh, splendid, You make my year. I do thank you.
