Plexiglass like material
  • Plexiglass like material
    Hi There,
    I'm struggling to make this material. It either becomes too reflectie or too dark. Can anybody help? Thanks!
    Hello maarten_vis,
    Can you please share a photo reference of what kind of Plexiglass you are attempting to create? It can be clear and frosted, I suppose you need a frosted one?
    Natalia Gruzdova | chaos.com
      Hi Natalia, yes, its should be a frosted one that is slightly transparent, but I don't have another photo reference. I particularly struggle with getting the items and lights behind it to be blurry.
        Here's some pictures!
          Hi maarten_vis, thanks for the reference and for more information.
          I am attaching a simple scene and the material that I have tested, hope this will be helpful.
          Basically, I have used Cosmos Glass material and changed some settings, you can tweak them further and test what works for you.
          Here is my result.
          • Change Reflection Color to make reflection more visible and if you need them to be blurry lower the Reflection Glossiness.
          • The same way you can control Refraction and it is a good practice to check the IOR of the material (some Plexiglass has IOR of 1.488 so I went with it, but you can change it of course)
          • And I have added Volumetric Translucency, you can read more on what it is in our documentation and test results with it disabled to see the difference (especially in shadows).
            Thanks so much for this, really helpful!
              I think this video will help you:
              https://www.youtube.com/watch?v=0UgKw3ZZd5o&t=423s
