Denoiser on effects result channel only
  • Denoiser on effects result channel only
    Hi there,
    When I render I get the denoiser only on the effects results channel. The main render doesn't have any denoiser applied to it. I do have a denoiser render but that doesn't have any settings from the frame buffer, like exposure. ideally what I like to do is have the effects result later on top off my render without any effect results, so that I can tweak the or mask it. How do I get that to work?
    Hope you can help!
    Maarten
    Hello maarten_vis,
    I am not too sure that I understand what you want to get as the end result based on your description, but you can try to change Denoiser Mode in the V-Ray Asset Editor settings:
    Click image for larger version  Name:	Denoiser_mode.jpg Views:	0 Size:	89.1 KB ID:	1184458
    By default the mode is set to Show Denoiser Channel and you could try to change it to Hide Denoiser Channel, and test if this is what you are looking for.
    You can find descriptions of each option here in documentation.
    Natalia Gruzdova | chaos.com
