Vray for sketchup, Bercon noise vs noise A and noise B
  • Vray for sketchup, Bercon noise vs noise A and noise B
    Hi Konstantin
    What are the difference between bercon noise and the noise a and noise b.
    In what kind of scenarios is better Bercon noise than the noise A and noise B
    This is only possible with vray for maya and vray for 3d max
    But i wonder when vray for maya or vray for 3d max users talk about that noise what does it really mean??
    For architectural rendering when do you choose this map the bercon noise over the other noise like A and B?
    Where is better to use the bercon noise?
    Do you think with time we can see this procedural map in vray for sketchup?
    Thanks
    The Bercon noise just has a different set of parameters.
    We can easily add it to V-Ray in SketchUp but I'm not sure that it'll be much of an improvement.
    If nothing else it will increase the complexity.
    I'll think about replacing one of the existing noise textures with the Bercon Noise. This might make sense because Noise A and B are quite similar.
