Material conversion vray material crashes
  • Material conversion vray material crashes
    Material conversion vray material crashes,Is there any ruby code that can directly convert the material's diffuse map, UV texture, transparency, retain, and remove all other parameters of the old version.This option may still need to be improved.
    See the scene materials in the attachment for details.
      no crashes on my side. I can convert your materials without any problem.
      Windows 11 - RTX 3090 - AMD Ryzen 9 5950X - 128 Go RAM
      Sketchup PRO 25.0.634 + V-Ray 7.10
      3DS Max 2025.3 + V-Ray 7.00.08
      3DS Max 2026 + V-Ray 7.00.08
      Chaos Vantage 2.8
      GeForce Studio Ready Driver Version 572.16​
        Hello, wzfwzfwzf,
        Can confirm DCHA34 's result that conversion of SketchUp materials from your model works fine.
        Please ensure you use the latest V-Ray version v6.20.01.
        If the issue persists, please try again by first disabling all 3rd-party extensions in SketchUp except V-Ray.
        If this does not help, please provide for investigation a crash log and dump files (located in %TEMP%) via https://support.chaos.com/hc/en-us/requests/new
        Kind regards,
        Peter
        Peter Chaushev
        Let's keep in touch
          Originally posted by Peter.Chaushev View Post
          Hello, wzfwzfwzf,
          Kind regards,
          Peter
          bugsplat.Never understood the reason,Thanks for the help.
            Originally posted by DCHA34 View Post
            Thanks for the test.
