With the scatter command of vray 6.20.04 for sketchup, can I bypass obstacles?
  • With the scatter command of vray 6.20.04 for sketchup, can I bypass obstacles?
    For example grss attached
    Click image for larger version  Name:	SketchUp_b2ciSPEldd.jpg Views:	0 Size:	534.9 KB ID:	1212116
    Hi alexpacio2015,
    It is possible with Area Modifier - add your object and select Exclude option, please check the tutorial here.
    If you need any further assistance let us know!
    Natalia Gruzdova | chaos.com
      Originally posted by natalia.gruzdova View Post
      Hi alexpacio2015,
      Thanks for the reply I think I understood but I can't do it I'll send you the file see what I have to do thank you
        Hi alexpacio2015,
        Solved, Thanks for the suggestion
          Solved, Thanks for the suggestion​
          Great, thanks for the confirmation! Wish you great renders!
