CUTOUTS
  • CUTOUTS
    How can I use the SU cutouts with VRAY. I mean cutout images with an alpha chanel. In the image below I used a tree component with a material that uses a "PNG" images (including an alpha channel). You can see that the alpha channel is not considered and the entire components is transparent...
    CUTOUTS
    You would set the alpha channel as the transparency for the diffuse layer that you had the png on. It has been requested that we utilize the alpha automatically for this transparency but we haven't yet implemented this change.
    TutorialC explains this process in VfR - but the material editing part is essentially the exact same regardless.
    Joe Bacigalupa
    Developer
    Chaos Group
