The difference between materials
  • The difference between materials
    I just wanted to give a quick breakdown of what the different material types are as it was asked in a post today.
    • VRayMtl - this is the main V-Ray material. It consists of layers of different types that can be combined to make pretty much any material you can think of.
    • VRayLinkedMtl - this is a special kind of VRayMtl that is linked to a native Sketchup material. Essentially it will grab diffuse layer information from the SketchUp material and use it in a VRayMtl as a read-only diffuse layer. You can then append other layers to it, so you can "wrap" up a native SketchUp material inside a VRay material. When you create VRayLinkedMtl you are asked to pick a SketchUp material. After you've done this the VRayLinkedMtl will be applied to any object in the scene that had the SketchUp material on it.
    • VRay2SidedMtl - this material can be used to fake transluceny or very thin materials like paper or curtains. It is still under development and is not working completely as it should.
    • VRaySkp2SidedMtl - this is a two-sided material that acts the way SketchUp's two-sided materials work. Each side is completely independent of the other.
    I hope some of this basic information is enough to answer some of your questions regarding the different material types while our tutorials are being created.
    Joe Bacigalupa
    Developer
    Chaos Group
    Joe
    You post is just what is needed to jump start
    even the pros.
    The basics of just how things work first and
    then we could use info on the settings and
    how they interact.
    For sure Vray is a killer for features, but in math
    parlance most of the SU types like myself want
    to avoid the "Factorial" multiplication of endless
    incremental settings that bump in the night.
    Don't want to be a big mouth, but a smart
    point and shoot version would sure be nice.
    Cut and try till you die gets old very quickly EH?
    Dave
      dtr-
      there is a resource out there which has a those kind of explanations. Its called Spot 3D and itsis a great resource for explanations of all of the vray functions. Its directly from ChaosGroup (the guys who wrote Vray) so it is completely reliable. It may be slightly more technicall than Joe's explanation above, but it is easy to understand and can tell you about every nook and cranny of Vray.
        Hi Damien
        I have read the ref and thx for the heads up.
        I know you guys are doing your best to get this all together
        but I for one have just had enough of learning curves and
        would just kill for the smart point and shoot render app.
        The render for Architects is just not a life in itself, but a tool
        to explain the project to the whomsoever and get on with building it.
        Sketchup has just set the bar for ease of understanding and use
        and the render that matches will win the day without a doubt.
        No disrespect intended, but if V is a grind to get to OZ,
        even for free I would miss the trip.
        The "huddled masses" await !!!!.
        Hope y'all can work it out as V is a real jewell for results that I have seen.
        Cheers to all
        Dave
          Yeah that seems to be a common feeling among Sketchup users.
          Joe Bacigalupa
          Developer
          Chaos Group
            Hi Joe again
            First it is known to all just what a good bunch you guys are
            and I hope you know that most who comment are trying to
            be both positive and honest.
            The Max bunch either don't have any work to do or are dedicated
            render zombies chained to their workstations.
            The "Little People" are fast tracking and multi-tasking
            24-7 and need real power in a simple format.
            SU just changed the World in one clean shot.
            The ball is in your court and the Great Race is really on.
            "Nothing is too wonderfully to be true"
            Faraday
            Time to party
            Dave
              Yep - I'm not upset by the reactions or comments from anyone. We expected this was going to be a different experience for us. The purpose of the beta for us was to feel out the Sketchup user and test our product, since none of us are actually full-time SketchUp users. So any feedback is good feedback - I'd much rather be told why someone would choose another product over ours than have them sugar coat it to "not make me feel bad". Any comments are just going to focus our attention where its needed.
              Joe Bacigalupa
              Developer
              Chaos Group
                Re: The difference between materials
                Hi Joeb,
                Taking the K.I.S.S principle in mind, i wonder if things can not be made more simple and comprehensive.
                Do we really all those different types of materials? Why can't these functionality be implemented in to one and the same vraymaterial system?
                Here some suggestions to make things simpler:
                step 1:
                Wouldn't it be easier if all sketchup materials would be automatically linked as vray materials and you can start from there?
                In this way the 'vraylinkedmtl' doesn't have to be a seperate type of material anymore since all SU materials become vraymtl by default.
                step 2: In sketchup there is an option to assign a different texture to each side of a surface.
                Why can't we just assign two different materials in vray for each side instead of using the vray2skp2sidedMtl?
                Is this new type of material necessary?
                step 3: the VRay2SidedMtl.
                Why not making a 'thickness' option in the ordinary vraymaterial instead of having to use yet another type of material.
                I am not a programmer but I have the feeling that things can be made more rational. Instead of just adding new things as separate functions with strange names there is a need for a general concept/strategy behind the software.
                Sketchup itself has a very clear and simple strategy that is easy to read and appreciated by its Pro users.
                Otherwise we would all be using Lightwave instead...Not
                Joeb,
                I know you guys are working very very hard to make vray work with sketchup.
                You probably didn't expect to have such a 'whining' audience.
                Those Sketchup users sure are a whacky bunch..
                Good luck with further development, i am sure the software will become super.
                  Ok - yeah! That is a good idea. So the material editor will start off populated by the Sketchup scene materials. I do think we should maintain separate material types, just for clarity and so we don't have one uber-cluttered material (especially since most people feel we have too many options already )
                  We did this like that before but we felt it was too cluttered. Since we can't use the simple Sketchup paint-bucket it became became necessary to add stuff to our context menu. So our context menu was filled with extra clutter - basically 2 of everything for a front and back side
                  I'm not sure of the logistics of this, it is an interesting idea, but the thickness idea is basically using real translucency - the idea behind this is its a kind of "hack".
                  I suppose our problem is that we are trying to stay true to V-Ray and stay true SketchUp. So the naming convention you see currently is adopted from the way V-Ray names its materials. As you may, or may not, be aware we also develop our V-Ray for Rhino plugin. So we are trying to have a "global" interface that can go with us whereever we go. So we're trying to weigh the different users of different applications together to meet in a common ground. Your suggestions are valid and will definitely lead to some discussions around the office
                  Joeb,
                  I don't see it as whining - SketchUp is a very direct, simple and powerful tool. We're excited to be here, and are confident we'll find our market, but there will always be growing pains as we move into place
                  Joe Bacigalupa
                  Developer
                  Chaos Group
                    Thanks for those answers. The things you say all make sense.
                    However , concerning double faced materials, I bet people will try to assign a different vraymtl to both sides because it's a natural and intuitive reflex to do that , only to find out it doesn't work like that and another type of material is needed.
                    Expect some repetitive questions about that in the forum when final release is out.
                    By the way, both sides are easily assigned from the 'entity info' panel in SU when the surface is selected.
                    Just click on one of the two side materials and you 'll be able to reassign.
                      You can assign V-Ray materials from the entity info panel? I didn't think we had access to any of those floating panels.
                      Joe Bacigalupa
                      Developer
                      Chaos Group
                        No, i meant Sketchup materials.
                        If the sketchup textures would be automatically linked as vraymtls as suggested above, yes, then you could say vraymtls can be setup that way.
                        By the way, that 'autolinking' of SU materials can be taken even one level higher:
                        After setting the vray parameters of the autolinked material and saving that material , these settings could automatically be transferred to other SU files where you choose that SU material.
                        In this way, applying a native SU material can automatically connect to a saved vraymaterial with all presets ready. ( this could be done by a script that autoconnects a vraymaterial to a SU material by name (vray can execute a query command to look for corresponding vraymtls that are preset. If the query doesn't find a corresponding premade vraymtl, it will automatically make a 'blank' vraymtl just sharing the same diffuse map as the SU material. The user then can start from that 'blank' vraymtl and set all needed parameters and save it for future 'autolinked' use, even in other files )
                        In other words: apply a sketchup material and you are done!
                        This would make the workflow very easy and fast and this method stays loyal to the vray system..A very WYSIWYG workflow.
                        In this way,users can build up their own little linked library of vraymatls that corresponds to the SU materials in their SU material list.
                        After a while every sketchup material will have a corresponding vraymtl and the workflow will get faster and faster.
                        Users could even start sharing full SU material libraries and the corresponding vraymtl libraries with eachother or through the forum.
                        I hope this explanation is clear . English isn't my native language so i hope the message is understandable.
                        Regards,
                        Biebel
                          I like your ideas - that could definately work for us. I guess my question is what happens for those users who want to just create V-Ray materials, should I create a SketchUp material counterpart to be applied in the scene via the paint bucket?
                          Joe Bacigalupa
                          Developer
                          Chaos Group
                            Yes Joeb! It's sounds like a good thing that biebel is sugesting - that is how i would like to work. Just to be able to start sketchup set up different colors for all the different materials - then when done building i go into vray editor and apply different settings to each material - or load a existing material INTO the material that is allready defined. So i paint with a yellow color and name it Gold - it's not gold but when i go into vray material editor i would then just load a material into that "slot" or allready defined material.
                            Fluke73<br />==============================<br />www.flukeworld.com - private (has gallery)<br />www.webzoo.se - my company
                            • #15
                              ...mmm, i haven't thought about that.
                              Can making the sketchup material counterpart be automated as well?
                              Maybe it can be made so that if you use the same name for the vraymaterial as the sketchup material they get automatically linked?
                              In that way, the user just makes a new SU material. If he names it the same as the presaved vraymtl, vray automatically recognises it and links them.
