I've been trying to create 2d entourage billboards, and I can't seem to get a right scale with bitmap materials (jpg). I did go throught that VRAY tutorials for rhino, but I guess scaling the image is not a problem in rhino. I tried from changing jpg's dpi to its image size, but it doesn't seem to work. The only way it worked was when I change the scale of the object in SketchUp, then the entourage image also changed its scale; however, this doesn't seem like a very good solution to get an exact dimension, such as height or width, per each entourage. Can anyone help?
Plus, when I apply "VRAY link material" to have the billboards, it doesn't show its jpg image, unless I delete its diffuse layer and recreate it. And once I get out of the material window, I can't get its preview when I re-open the material window.
Is it just me?
thanks.
Is it just me?
thanks.
