How do I link a sketchup material applied to my model with a Vray material? If I update the Vray material will SU material In the scene update?
Skethup + Vray Material Link
Re: Skethup + Vray Material Link
On the subject of vray linked material, I seem to have problem revising the material -- I updated the diffused color, previewed it alright. Then I clicked on other materials to revise, and when I click on the first material again, the color stayed what it was when it was linked from SK. Any thoughts?
The Linked material always gets the diffuse layer from the SketchUp material. If you see a little red ball next to the layer name that means its read-only. The link between VRayLinkedMtl and the SketchUp material is always there - so if you want to change that diffuse color you need to change it via SketchUp's material editor. Any other layers you may add to the linked material can be edited by you - as long as you don't see a red ball next to the layer name you can do whatever you want to that layer.Best regards,
Joe Bacigalupa
Developer
Chaos Group
