does the sun settings of sketchup works with hdri maps? how do i configure it?
HDRI SUN
Re: HDRI SUN
more likely i was asking about my problem on why when i use a hdr, the shadows from the sketchup model doesnt appear when i render..
i ve been able to make it work only if i use the vray sky setting.
thats why i ask if with a HDR we are limited to not have the sketchup shadows?.
Re: HDRI SUN
Hmm - yes I made it so if you use the sun without the sky texture it just gets used as a regular direct light. It won't have the same brightness, but the direction of the sun is preserved.Best regards,
Joe Bacigalupa
Developer
Chaos Group
Re: HDRI SUN
Originally posted by Joe BHmm - yes I made it so if you use the sun without the sky texture it just gets used as a regular direct light. It won't have the same brightness, but the direction of the sun is preserved.Please mention what V-Ray and SketchUp version you are using when posting questions.
Re: HDRI SUN
I've always had Default Light on as it's ticked in the default settings. However, when I set a HDRI as the GI skylight environment map there is no shadows. It all turns soft. Looks like it's just the HDRI in effect.Please mention what V-Ray and SketchUp version you are using when posting questions.
Re: HDRI SUN
This thread is very relevant for me at the moment.
I do a lot of photomatching, and sometimes the reference photograph is taken on a cloudy day (this is Britain!) so the shadows are very soft - but still present.
I have been fudging it (cheating) by using the physical sun and having strong shadows on my model, but recently decided to try HDR in the environment slot. I have some degree of success, but it is tricky getting a HDRI which has enough 'punch' with its hot spot to get a shadow at all. The shadow you get from the physical sun is much too harsh and defeats the object. This shot is the best I've got so far.
David
Re: HDRI SUN
That's exactly what I'm doing as well. I prefer photos taken with some clouds as I find it's nice to have something to fill out the sky and it makes for a nicer colour balance avoiding too much glow and glare.
But I've yet to find an HDRI that actually produces any sense of directional shadows. Can you recommend any?
Is the image you posted lit by only HDRI?Please mention what V-Ray and SketchUp version you are using when posting questions.
Re: HDRI SUN
Have you had any experience with Hyperfocal's HDRI maps? They look interesting. http://hyperfocal.vismasters.com/cat...x?product=3611Please mention what V-Ray and SketchUp version you are using when posting questions.
Re: HDRI SUN
Well, It would seam that something is up, because there should still be the sharp shadows from the default light. Maybe there's something about not being connected to the sky that throws things off...I'll try and take a look today.
On the other side of the coin, you're going to be hard pressed to find an HDRI that will really give you shadows that rival any sort of lighting. Because of how HDRIs it just becomes really trouble some to have a texture that will generate distinct shadows. The other components to this, is that if you did have a texture that could do really well with those shadows, then there would probably be other kinds of reflection or glossiness artifacts within the scene. And for the icing on the cake, a texture thats going to generated decent shadows is going to take longer to sample. I'm sure that doesn't help, but maybe it explains it a little bit.Damien Alomar<br />Generally Cool Dude
