Spawner
  • Spawner
    Does the spawner exists for SU?
    Re: Spawner
    Yes the spawner exists for sketchup. In fact if you check the installer, then you should be able to use that to install the spawner on other machines. If you load up the installer, and where is says if you want to do a Typical or Custom installation, pick Custom. From there you can change whats installed to only be the spawner (the slave machines will not need the full vfsu to run). That will install the spawner in the C:\Program Files\ASGvis\Render slave folder, and from there you can launch things. Hope that helps.
      Re: Spawner
      Yes, thx
