Distributed Rendering
  • Distributed Rendering
    So after a good few hours getting my DR to work with SU, I have set up an animation. It works fine as far as the animations, the problem is that after it runs the first scene, the linked computers processors drop out. Basicily the first image renders using 4 render squares(2 mine, 2 the other) then the second scene runs only my 2. If there is a simple setting for this and I missed it I would apreciate the assistance.
    thanks,
    -C
    Re: Distributed Rendering
    Could you send me a scene that demonstrates the issue? I'm not sure what could be going on.
    Joe Bacigalupa
    Developer
    Chaos Group
      Having the same problem. Distributed Rendering works like a charm on individual frames. But when I try an animation I get the first frame with all processors working then the rest only use my machine. In the vray-process window i see the job bieng sent to other machines but the dont seem to do anything with it.
      Did you guys resolve this or is it something i am doing wrong?
