DRSpawner.exe
  • DRSpawner.exe
    I would like to try DR - but where do I find the DRSpawner.exe file ?
    Jorgensen
    Re: DRSpawner.exe
    Found it
      Re: DRSpawner.exe
      What is DRspawner for? Sorry for asking..I'm quite new to this.
        Re: DRSpawner.exe
        It's the client you run on other computers - this allow you to use the power of ten computers in one render
        Easy to setup - and very powerfull...
        Jorgensen
          Re: DRSpawner.exe
          Is it possible to run DRSpaener as a service, so it doesn't appear as a program ?
          Jorgensen
            Re: DRSpawner.exe
            That is on our todo list actually. I'm not sure if you can do that now though
            Joe Bacigalupa
            Developer
            Chaos Group
              Re: DRSpawner.exe
              Ok, it would be nice - if it was possible
              jorgensen
                Re: DRSpawner.exe
                Indeed, I got a nice quad 2.66 sitting just next to my computer, waiting to slave some work for me
                  Re: DRSpawner.exe
                  How does it work if we have two licenses and run DRSpawner on four or five other machines - and both wan't to render via Distributed Render ?
                  I'm looking foreward to be able to install the DRSpawner as a service - my colleagues are a bit irritated about the extra window. And by the way, DRSpawner craches one or two times a day
                  Jorgensen
                    Re: DRSpawner.exe
                    May seem like a silly question but is the DRSpawner available on the 30 days download?
                    Can't seem to find it and we are looking to test this application, or is it a seperate download / cost?
                    Thankyou for your time in reading this.
                    M
                      Re: DRSpawner.exe
                      I don't know if it is. But try to install and select the 'special' install - if possible
                      Jorgensen
                        Re: DRSpawner.exe
                        Yes it is available. Read my post here for the details on how to find it/install it. The spawner should already be installed if the machine has vfsu installed on it. Check in c:\program file\asgvis\render slave
                          Still cant find DRSpawner.exe
                          Hi, I read the forums here regarding DRSpawner and how to install it. Somehow I cant seem to find that option in the custom install or the spawner installed anywhere on my PC. I have VRay for Rhino 1.0... is the drspawner available for this version and if so where?
                            Re: DRSpawner.exe
                            Adding to the previous comment... the drspawner is not in program files/ASGvis/Render Scene or any where in the program files named either DR Spawner or Render Scene.
                              Re: DRSpawner.exe
                              Jorgensen
                              I tried to run it. It says..."Successfully loaded the ASGvis distributing rendering slave..Hit CTRL-C to exhit."
                              Then what? What will I do after I run this program? I'm on network(1 pc and 1 Laptop) using wireless router. Will the DSpawner help me render my drawing fast using my other pc's power?
                              Sorry for the dumb questions....
