Displacement in SketchUp?
  • Displacement in SketchUp?
    No mater what i do I can't make displacement work. Bump mapping works fine but displacement is no go. Following V-Ray for SketchUp Manual and have no luck at all.
    Ether I am missing something or maybe it is not implemented yet? Then why it is in a manual....
    I am sorry if that was asked before but i could not find answer on a forum. Everywhere i go it is advertised as Displacement works.
    I only see people having problem with bump mapping... but that aspect i was able to solve.
    Re: Displacement in SketchUp?
    It is implemented in our core technology - and is in use in Rhino. It should also work in Sketchup. I'll see if I can get an example scene together for you.
    Joe Bacigalupa
    Developer
    Chaos Group
      As for displacement, it is working. The multiplier for displacement will reference your scene units, so that may wind up being a bit to small to really notice. You can try increasing either the texture multiplier of the displacement map, or under V-ray options go to Displacement and increase the Amount.
        Thank you guys.
        I was doing everything you sugested but without any luck... and then it worked.
        Don't know how do not know why... but it works now.
        Thank you for all your help
