Question for SketchUp user - camera projection needed?
  • Question for SketchUp user - camera projection needed?
    at my wishlist for Rhino is a Vray camera projection based texture. It's something, that Vray dosn't support now, because 3dsmax support it. But if the new Vray plugins need it, because the 3D application don't support it, than it should not be a problem to implement it (it equal to the environment projection type). Befor I post a wish to Vlado my question: does SktechUp support texture camera projection? If not, than Rhino and SU user need it.
    Camera or frontal projection allow it to use a standard photo of a environment (a nice place at the city for example) and project it to a simple 3D geometry (for example a ground surface). If the the viewangle to the CG groundplane is adjusted so that it match with angle real-worl-camera and real-world-ground, than the illusion is perfect: high detailed photo ground for CG objects. Some examples are visible at my VfR gallery, done with a rhino tool, that works, but not perfect.
    This projection method is great in combination with a HDRI. Often, the problem is, that the resolution of the HDRI could be better, the background looks pixelated. Simple solution: use a camera mapped photo of an equal environment. Most, it's not visible, if HDRI and photo are not from the same place. (I add a fresh image at my gallery today based on HDRI and backplate image).
    Some examples:
    - CG car at street env
    - jewelry at a human hand env
    - office things at a desk env ...
    -Micha
    Re: Question for SketchUp user - camera projection needed?
    Micha
    Is this a bit like sketchup's photomatch? So if we used photomatch, then we could place the model in context? Is that what you mean?
    David
    Sketchup 2015
    Vray version 2.00
    www.davidcauldwell.co.uk
      I'm not sure. For example my gallery image - a red frog on a street. The street image is a photo done with a small digital camera. This photo is projected through the camera to the soft ground plane. Does VfSU support something?
        Micha
        OK, I found the frog! I can see that this would be a usefull feature - I think. The closest that sketchup comes to this is photomatch, but the photo doesn't get rendered in vray. I use the photomatch feature a lot, so if it enabled you to place your model (frog!) in context then that would be great.
        David
        Sketchup 2015
        Vray version 2.00
          Camera mapping is available at the SDK, so Vlado. Now, I'm curious what Joe means.
          http://www.chaosgroup.com/forum/phpB...=175984#175984
          It's a pity, that DOF can not be used for this easy setup and I don't understand why.
