water effect
  • water effect
    hi guys
    has anyone here did a sample on how to make water effects? can u link me to it if there is a topic.when i try it i get flat and plain blue result.
    thank you.
    ;D ;D
    Re: water effect
    welsh,
    its fairly easy. this is my humble advise for a quick water effect.
    1. add water material in sketchup. be sure your water material has also bump texture (inverted black and white image using photoshop)
    2. create linked material.. then add reflection map
    3. the add the bump map...
    http://www.nomeradona.blogspot.com/
    http://www.sketchupvrayresources.blogspot.com/
    http://www.nomeradonaart.blogspot.com/
      Re: water effect
      ...after which i usually remove the texture from the water... so that its just a cour with a bump map...
        Re: water effect
        thank you nomer and freeagent ....ill try it...thank you ;D
