need help with sketchup linked material
  • need help with sketchup linked material
    hello,
    i have a problem with a sketchup linked material. i added a wood material in sketchup materials. then i positioned it. then add the vray linked material to the vray material editor. But when i rendered the texture isnt at the same place as in the sketchup model. i tried everything. please help
    Re: need help with sketchup linked material
    Is possible to get the SKP ?
    (with the texturemap )
    Hard to tell without it
    I guess same material was applied on different group hierarchy..
    thomas(at)quickit.be
      i have the same problem
      i created a VrayLinkedMtl, when i render the scene the material is misplaced.
      heres the right position on SU
      this is how it looks after rendering- misplaced
      i'm using v.1.00
      on xp
      www.Top3Dstudio.com
      SU 8
      VfS 1.48.89
      Win 7 64-bit
        i figured out the problem
        Here's the solution:
        1. "reverse Faces" by right clicking on the face in sketchup
        2.reposition the texture in SU
        3.render and see the position linked
        www.Top3Dstudio.com
        SU 8
        VfS 1.48.89
        Win 7 64-bit
