rendering
  • rendering
    why does the v-ray for sketchup render hang up some times? sometimes it just doesn't do anything when i click the render button. except lock up the file.
    Re: rendering
    V-Ray has to get all of the information from the file that is needed to render (geometry, lights, materials, mapping). This may take a little long if you've got a lot of objects in the scene.
      Re: rendering
      But when I make a large moddel and I whant to change a texture name (v-ray texture) it thake`s verry verry long before it does what I want..? will the first update solve this and what can i do about this.
      and when I render a large moddel some time`s my SU give`s a runtime error... When loading the geometry etc. Houw can I solve this
      Thanks
      112
      www.DWanimations.org | Makes your work come to life
        Re: rendering
        The material thing stems back the same issue. Material wise, it will be more noticeable if that material is applied to a number of objects or to a high poly object. Its really traced back to how SU actually stores its geometry, which isn't the prettiest thing (so I'm told). Joe has tried to do his best with speeding all of this up, but there's not anything we can really do if its related to how SU chooses to do things.
