edit lights wholistically?
  • edit lights wholistically?
    Is there a method to editing light intensity wholistically. For instance, I'm test rendering an image with multiple omnilights representing recessed lights. For now, I have been changing the intensity of each light individually. Is there a better way?
    Thanks!
    Re: edit lights wholistically?
    Unfortunately at this time no. I will put this in the wishlist though.
      is it possible to create the vray lights into a component? that way if you modify one of them then the rest should be updated as well at the same time. in other words, bring out one of the vray lights (omni or plane) in a scene in SU and make a component. in that scene, create few of them of the same component light. if you modify one and i assume the rest will be modified as well, right?
        I think it´s doesn`t work.
        the omnilights are already component, I tried to modify one of the them witch copyed from the another, and rest of them doesn`t get the changes.
