Materials not working properly in sketchup
  • Materials not working properly in sketchup
    well, i created some materials in V-ray material studio, saved them, and applied them to a surface in sketchup. when i render there is no bump or displacement in my renders.
    this are my materials
    and this is how it looks in sketchup
    also, thebump doesn't work
    if i use a grayscale of the normal image for bump, i get no bump but is i use the normal image with displacement and set it to invert i get bump.
    but not in sketchup
    how can i get the same materials i create in materail studio working in my sketchup renders.
    (already tried physical camera off, light emitters etc etc)
    Re: Materials not working properly in sketchup
    The bump and displacement features are rather hit or miss in SU because of how SU handles the geometry. Bump will usually be more reliable then displacement, but having objects within groups tends to throw things off a bit. There was a post around that proposed a good workflow for setting up displacement so that it works...do a search and it should come up.
      you mean this topic?
      http://asgvis.com/index.php?option=c...0&topic=2632.0
      i'm trying al his options right now
      i had my grass working last time but when i wanted to test my marble and added it, everything was flat again.
      my stone wall is getting allong good, i'll post a render in a minute.
      then i'm going to try it with multiple materials
      btw, if i understand this right. it's useless to create an material in materialstudio becouse it wont work properly in SU?
      here is my render
      rectangulair light obove the midle, double sided
      it works
        ok, i got it working
        for flat surfaces you must use displacement, for 3D (walls) you have to use bumpmap (the way i use it now)
        tomorrow i'll find out an better way xD
        quick model and render
        i'm thinking about creating a tutorial with the basics becouse right now there is no good tutorial explaining bump mapping
          Dear Wagori,
          Hi, I'm a newbie here. May I ask wht setting should I apply to render a night club? I facing difficulties here. Ur help will be grealy appreciated. Thnx.
            if you mean the lights setup. take al look at this tutorial
            http://www.xeav.net/index.php?option...sk=view&id=117
