render output size
  • render output size
    im having problems with the size of rendered area. how can i render what is being viewed on the monitor screen? only a portion of the viewed area of the monitor is being rendered. how can i adjust the settings?
    Re: render output size
    If you are using the physical camera, then adjust the camera zoom - try 0.8 or 0.7.
    David
    Sketchup 2015
    Vray version 2.00
    www.davidcauldwell.co.uk
      thanks, ill give it a shot. btw, where can i get glass materials? i only use transparencies and it doesnt give the same effect as glass, no reflections.
        You should have 'clear glass' as part of your vray installation, together with some other basic materials - metals etc. Have a look in the programme directory.
        David
        Sketchup 2015
        Vray version 2.00
