Try to put bitmap but cant fit well ...Help me please
  • Try to put bitmap but cant fit well ...Help me please
    If anyone know how to insert a bitmap for a Tv for example and with emisive and the most importantt HOW to fit correctly the image to the space that you need ..
    Re: Try to put bitmap but cant fit well ...Help me please
    Sketch Up doesn't create UV coordinates unless there is a SU material with a texture applied to it. So make a SU material with the image that you want to use for the screen and apply it to the surface. Use the SU mapping tools to place the map where you need it. Then make a linked material from the SU material. Add an emmissive layer and put the map in that layer. Adjust the intensity so that the image shows up (this may need to be alot if you have the physical camera enabled). The image should be exactly where you placed it.
      THx it works just perfect ... the thing that i still cant do is to put a background correctly becouse i cant fit the image correctly..
