distribute render with hdr
  • distribute render with hdr
    hello, i have one big problem, when rendering with distributed rendering with an hdr image of background the slaves machines render black buckets and only the host machine do it well. but when i use physical camera it works.... does anyone knows why???
    Re: distribute render with hdr
    does anyone had the same problem????
      Its most likely because you don't have the same HDRI image located in a shared network location. Make sure that all the images that VRAY references are in a location that all the slaves can read from. Try that.....
        Also double check if you have some missing textures on the materials.
