do saved irradiance map can be use in distributed rendering?
  • do saved irradiance map can be use in distributed rendering?
    Re: do saved irradiance map can be use in distributed rendering?
    Thats a good one...they should be able to, but I'm not sure of the status on that one. I'm not in too much of a position to try at the moment, but I'll see if I can get DR setup on my machines and try it out
      thanks for the reply. I hope you can test it..I have a problem doing dr with saved irradiance map,in the slaves machine it has problem rendering in areas where the bucket renders like, it renders black,sometimes gray, and sometimes the textures are missing..but in my own machine theres no problem only in the slaves machine. I hope you can find solution to my problem...
        Chances are thats a bug with the DR settings getting the right environment info. This was fixed with the new builds that have been posted, but I would suggest holding off if you can on that since the newer builds changed a lot of other things, and there are still a few kinks to work out.
