Two questions about materials
  • Two questions about materials
    Quite a collection...
    1.Is it possible to transform a regular VRayMtl to a VRayLinkedMtl? I import a lot of materials and still want to control UV mapping in sketchup - and only way I know to copy properties from VRayMtl to a VRayLinkedMtl is to rewrite them manually.
    Is there another way?
    2.When i add new objects and assign them a sketchup material, a VRayLinkedMtl isn't assigned automatically. If these new objects are deep in groups/components hierarchy, then assigning materials requires opening each of them for edition - which is quite time-consuming. Is there any workaround?
    thank you in advance
    Pawel Kosmicki
    Re: Two questions about materials
    The Service Release automatically links all SU materials with V-Ray materials. That should solve both your questions when it's released.
      what is the "Service Release" ??? :-\
      Juan Carlos
        A service release is basically a software update, but not significant enough to warrant a whole new version. Usually there is the connotation that the goal of a service release is more to fix certain issues then it is to add new features, although the actual adherence to that depends on the development habits of the company.
          explode all groups and attached material and group again.Thats the only way i know so far
          www.jackscabana.co.uk
            OK, and when this Service Realese is supposed to be available?
