The glass is not letting pass trough the light..
  • The glass is not letting pass trough the light..
    i have a problem and is that The glass is not letting pass trough the light..and the interiors are very dark how can i configure the glass material whitout moving the sun multiplier what shoud I do ???? ( SORRY !!! for my english)
    Re: The glass is not letting pass trough the light..
    you have plane - add material to both side of plane - then it will work caorectly , every plane has two sides
      I only find it necessary to apply the vray glass material to one side. I ignore the sketchup glass and apply a vray glass, so sketchup won't let the light through, but vray renders will. Make sure that the vray glass material has the 'transparency' colour set to white (normally you don't touch this setting). If you download one of the glass vismats, it should work ok.
      Here is a test scene, using 240, 60 glass. Note that the billboard, on the left casts a shadow (it doesn't in sketchup)
      Here is the set-up in sketchup
      Good Luck
      David
      Sketchup 2015
      Vray version 2.00
      www.davidcauldwell.co.uk
        mANY thx !!! i tryed and it works just fine and seting the transparency to white solve the problem ,,,.THX
