distributed render problems
  • distributed render problems
    hello folks... i want to ask a question. DR works for animations too??? because i've been trying to use DR for an animation and it only works with the first image but it stops with the next 120...
    is DR programmed to work with animations??? :-\
    Juan Carlos
    Re: distributed render problems
    This is a known issue, and currently DR will not work for animations. Sorry.
      thanks for the quick response dalomar
      do you know if there will be an improve in this area in the Final Release???
      Juan Carlos
        Not 100% sure...DR will be working much better and much more stable when the SR is released, but I'm not sure if any headway has been made on this issue. I'll try to do some testing and see what comes of it.
          any news on DR for animations?
            hi there! I' m from paraguay, I'm using the vr for su, but i'm having some troubles. one of them is that i can't use slave machine, i disconected everything on the firewall of windows in both machines, but it doesn't work anyway. need help!!! the other problem is that my su is running extrimly slow, don't know why because i'm using a quad core, 2gb ram, nvidia gforce 7100 512mb. so, if you can give a hand i'll be on debt with you. thank's (sorry for my bad english)
