Textureimage only when rendered
  • Textureimage only when rendered
    Is is possible to create a material, for ex. a grass, that is simple solid green in SU, and when rendered it gets the material image from the settings in VRay ?
    Thanks
    Jorgensen
    Re: Textureimage only when rendered
    yes
      or u could just sketchups display style to momchrome...
        Hi
        Thanks for your answers. The problem is, that i use a texture image, that look good when used as environment in Vray, but looks terrible in SU.
        Using monochrome, means that all my images dissapers
        What I need is the opportunity to create materials in SU that are seperated from Vray and the opposite. The only connection is the material name.
        Thanks
        Jorgensen
