Creating depth in materials with bumpmaps
  • Creating depth in materials with bumpmaps
    I'm trying to use bumpmaps to create depth in my materials but this doesnt work.
    Imagine a cube of 25*25*25 m, with a bumpmap that has a pattern. It should create vertical stripes on this cube. In the material editor preview it perfectly shows the depth I want to achieve. However, when rendering with vray, it shows a smooth surface.
    I tried to put lights on it, to create depth by shade, but this makes no difference. I tried to use the 'Vray for sketchup manual' and I looked in the materialoptions, as well the global options, but i couldn't find anything that could fix my problem.
    What other possibilities should I look for in order to make the bumpmap work?
    I hope someone can help me!
    Ruud
    Re: Creating depth in materials with bumpmaps
    i guess you're using the wrong mapping. the texture is there but the map makes the texture too small or too big so it won't show up.
    Juan Carlos
      How do u fix the sizing issue?
        You really need to do this via a linked material. If the object has a material applied via sketchup, then you can just right click on it, go to Texture Mapping (or something like that), and move it around in a pretty easy way.
