Z-depth
  • Z-depth
    I'm trying to get a depth map, but I'm not succeeding. I tried setting a near and a far plane in Maxwell Studio and the using the corresponding values in Vray (hope you know what I mean), but that didn't work.
    So ... how do you people do it? Eh? Well? Huh?
    Re: Z-depth
    No takers?
      Re: Z-depth
      In VFB enable Z-dept then render your image --> save it --> open the render in photoshop ->
      then place the Z-dept image on top of the normal render (in a new layer) --> go to channels --> copy one of the channels (now you have your z-dept Channel) --> (go back to your layers) delete the Z-dept layer that you put on top of your render --> go to blur --> select lens blur --> and select the Z-dept channel.
      thats it
      www.DWanimations.org | Makes your work come to life
        Re: Z-depth
        lol. Thanks for that explanation. Unfortunately, that's the part of the process I'm familiar with. lol. What I do NOT know, is which values to put in the VFB ("z-depth black" etc).
        But ... toch bedankt ('"thanks anyway")! ;D
          Re: Z-depth
          ik laat het allemaal gewoon op standard staan. werkt prima.
            Re: Z-depth
            You use the default settings? Really? I gotta try that then. Come to think of it, I think I already have. So far, all I ended up with, was either a completely black Z-depth render or one that closely resembles an alpha one.
              Re: Z-depth
              strange whit me I seems to work fine :S
                Re: Z-depth
                Are you lot working in imperial or metric? I think the number to use in the VFB is in feet only, even if your scene is in any other unit.
                  Re: Z-depth
                  It should be scene units.
                    Re: Z-depth
                    Ah, I was wondering about that. Good to know.
