With new vray sr1 I'm having a problem with xfrog trees..when I remap the leaves in the diffuse, all the leaves are not remapping right..any solution on this one?
xfrog trees
Re: xfrog trees
Its not a SR1 problem its a Sketchup Problem... use another 3d application to remap textures
if ur having this problem you probably not using xfrog tune which u can only use with another app like C4D or Max (to import the obj files it creates) once there u need to map ur already converted textures...
