Is there a way to collect all the maps used in the Vray material editor and put it in one folder like the resource collector in Max.
Collecting maps and materials from SU file.
Re: Collecting maps and materials from SU file.
Not directly, but if you check in the DR settings there is an option to put all of the dependencies into a shared folder. Enable that and set the location you want. Run a render with DR (you don't even need to add a node) and you should get everything.Damien Alomar<br />Generally Cool Dude
