HELP convert inches to meters... Bump?, Displacement?, I dont know
  • HELP convert inches to meters... Bump?, Displacement?, I dont know
    hi my name is Mauricio I am from Colombia. have had a problem with VRay for SU, as we all know the steps where we work are meters and the program comes in inches, which would require a conversion, but the models are working in meters and when imported into the damaged inches. moreover for the color and other difuse I give a value of .025 for me to take them, but bump map is not noticeable, nor speak of displacement that did not take it never
    Let me know that I can work as textures in meters (diffuse, bump, displacement, etc.) have done tests and not to do more to solve this I would like to advise me on this issue of conversions ... or should I do?. I thank in advance any solution that I can give or if the solution is in the import model please help
    Re: HELP convert inches to meters... Bump?, Displacement?, I dont know
    No need to convert. In SU, change the template preferences to metric.
    window/preferences/template/ - select 'metricmillimetres3D'
    or
    window/model information/units/select your preference.
    David
    Sketchup 2015
    Vray version 2.00
    www.davidcauldwell.co.uk
      but it does not work
      but what happens is that if you work in meters ITS .... VRay I do not change their actions and I like working in inches and can not apply materials with their characters ....
      please help
