Problem with glass
  • Problem with glass
    [img]http://www.flickr.com/photos/16879812@N07/2826934077//[img]
    I am having an issue with all the glass coming out blue (see image attached).
    The glass is a single plane. I have tried Vray glass and a 2 sided material with glass on both sides and both attempts give these same results. I have a lot of glass in this model and need to get this figured out.
    Any help would be appreciated.
    Scott
    Still trying to figure out how to add an image. Would be great to be able to upload right here
    Re: Problem with glass
    Scott
    How to post an image http://asgvis.com/index.php?option=c...sg9842#msg9842
    With the glass - make sure it is only a single plane (i.e. not push/pulled to give a thickness) and apply the 'architectural glass' from the downloads area. It should work.
    David
    Sketchup 2015
    Vray version 2.00
    www.davidcauldwell.co.uk
      David,
      It is a single plane but I will try the arch glass and see if that works. Thanks for your help.
      Scott
