vray sun and sketchup sun
  • vray sun and sketchup sun
    I'm having a problem coordinating this 2 options.
    I enable sun in sketchup and I check the "use sun for shading" options in shadow setting.
    But when I render it using MADO visopt, the sun in render didn't came up the same orientation as sun and shadows settings in sketchup. thanks for any help in advance.
    Re: vray sun and sketchup sun
    This sounds like the Sun re-set bug (which is fixed in SR1 !!!)
    In the environment - GI (Skylight) roll-out
    untick "Override Sun's parameters", hit 'apply' and then tick it again, and hit 'apply' again, that usually does the trick.
    (In other words you have to completely re-set this option after any changes in sketchup)
    David
    Sketchup 2015
    Vray version 2.00
    www.davidcauldwell.co.uk
      or just hit update under the preview square in that same window
        Thanks guys.
        Dcauldwell your right..
