MAP SCALING
  • MAP SCALING
    This is probably a simple topic for most.
    i cannot get a map to scale correctly. The image i have is the exact proportions as the object and i cannot get it to scale correctly using vray. I can get it to scale correctly with sketch up. But i need the map to be a transparency map and therefor sketchup materials dont work. Please help.
    Re: MAP SCALING
    You still have to apply the map in SU. Use your opacity map in your SU diffuse. Set that layer to be completely transparent. Then you create a second diffuse layer. Since the first layer is completely invisible it's the new layer that'll be rendered and you now have texture mapping co-ordinates which you can use in any other material layers.
