I'm working on an interior render. Here's the last version:
As you see, in the ceiling, some of the holes are missing. It should all be uniform. Initially lots of them where missing, but I found that changing Image Sampler from Adaptive Subdivision to Adaptive DMC corrected most of this. But a few still remains. I did a couple of other tests where I increased the Min Subdivs and also Max Subdivs, but with no better result.
I also tried a larger IR Suvdiv and Sample value, no better result. Also tried DMC instead of IR (as is recommended for scenes with lots of glossy) but with no better result in regards to the holes. The holes in the ceiling is not modelled, but it's a texture.
Also, the horizontal lines in the wooden panel, I'd like them to be smoother and shaper. And I want to get rid of the Moire effect. These horisontal slots in the panel is modelled. 5mm wide.
Right now I'm doing a new render with higher IM settings and Image Sampler to Adaptice DMC, Min Subdivs 2, Max 32, Noise Threshold 0.005. (haven't tried adjusting the noise before.)
Can anyone give me some pointers to how I can correct these issues?
