failed to create temporary file name (error 80: the file exists.)
  • failed to create temporary file name (error 80: the file exists.)
    I need your help here.
    Form yesterday, I am having a trouble with rendering. Materials are not applied to
    rendering image and whenever I tried to open Environment,
    "failed to create temporary file name (error 80: the file exists.)" message comes out.
    Rendering time got really slow..and all the materials are not showing in final image
    Whats wrong here??
    Re: failed to create temporary file name (error 80: the file exists.)
    Please send us the scene and fill out a support ticket. This sounds like something that we need to take a closer look at and of hand I don't know what the direct cause of this might be.
      I´m having the same problem!!! PLEASE could you help me to find the solution? It´s highly important!
        Problem solved...if you´re facing the same issue, you need to clear the TEMP directory. On a typical windows installation that folder is C:\Documents and Settings\All Users\Application Data\ASGvis\Temp Note that Application Data is a hidden folder.
