DRSpawner Issues again
  • DRSpawner Issues again
    I have 3 machines in my farm all of which are running the same version on Vray for Sketchup and all on the same internal network. The problem I am having is that the laptop I use as a backup is not rendering the same colors as the rest of the machines. I have a wood texture that the laptop is rendering darker then the rest. They are all pulling the textures from the same location. I am not sure as to how to fix this. I would like to use the laptop since it is a workstation and had a lot of power to add to the renderings.
    Can anyone shed some light as to why this might be?
    Scott
    Re: DRSpawner Issues again
    I have had these issues aswell. I just make sure all your textures are on the network. Also, I have to re-map the textures that are not showing up, or re link them and then that seems to work. I do have problems with some machines not recieving a scene even though they all have the same version of vray on them, and all the IP addresses are double and triple checked.
    - Doweth!
      Scott
      Hey Scott! Good to see you here, but not in the bugs section!
      I'm having the exact same issue
