Problem in rendering
  • Problem in rendering
    hi
    i faced two problems in rendering:
    1- i'v designed a building and i want to make render to it's elevations.. i used the paralell projection to look like 2d..but in render it looks 3d..can i fix this problem?
    2- in render, the edges doesn't appear.. how can i make it appear?
    thanks..
    Re: Problem in rendering
    Originally posted by Qusai
    hi
    thanks..
    1.: You're using Physical camera and that doesn't render parallel. http://asgvis.com/index.php?option=c...0&topic=5640.0
    2.: V-Ray doesn't render lines. Only faces. Though you can try the Toon material, it's quicker to just save a BW image from SU and overlay in post.
      Will V-Ray ever render lines?
      We create handrails w/ just lines and they never render.
      It is much faster to create railings & detail items w/ lines instead of solids
      Any suggestions or help?
      Also, IRender does render lines, I hope VRay does soon ???
      Thank you and let me know
      woodism
        maybe u can save a line image from sketchup and render with vray and mix them togheter with photoshop/gimp
          If you know Photoshop a little, than i would suggest you to use this Plugin (made by Thomthom): http://forums.sketchucation.com/view...st=0&sk=t&sd=a
          www.Top3Dstudio.com
          SU 8
          VfS 1.48.89
          Win 7 64-bit
            Never say Never...In the future it is certainly a possibility, but at the moment it is not really on our list of features to implement. There are also some issues with the way SU thinks about lines that complicate the issue as well.
