applying vismat as default
  • applying vismat as default
    Hi, does anyone know how to set vismat as default material... maybe a Ruby-Script.. bye devran
    Re: applying vismat as default
    Not possible. V-Ray doesn't even recognize the diffuse colour if you change it in SU.
    It's one for the wishlist.
      Can you actually tell me where the control for the Default color is?? I haven't been able to find it, so until we know where it is, we can't do much about changing it
        From the SU UI:
        Styles Window->Edit tab->Face Settings->Front Color & Back Color
        From the SU API:
        Sketchup.active_model.rendering_options['FaceFrontColor']
        Sketchup.active_model.rendering_options['FaceBackColor']
        You get the list of all options if you type this into the Ruby Console: Sketchup.active_model.rendering_options.each_pair { |key,value| puts key.to_s + ' - ' + value.to_s }
          Thanks...that seams a little buried if you ask me, but we should be able to do something about it. Thanks.
