Sketchup camera issues
  • Sketchup camera issues
    Figured it out
    Re: Sketchup camera issues
    You can change from parallel to perspective, ok, but I think it shoudn't appear. I mean, it must be a bug, right?
    I have the same problem here, but it occurs while orbiting in perspective mode. I think it's a graphic card problem, I have a Geforce.
    On Autocad while modeling (3D) I get a load of display errors, I can't work in it at home. I think it's kinda similar situation, probably graphic card problem.
    Cheers
    Gustavo
      If you experience camera clipping issue while in perceptive mode it's often because you're zooming into something really small, less than a couple of mm, or that you have your model located far away from the model origin. When importing .dwg files which has been drawn in real world co-ordinates this often happens, the cure would be to mode the model closer to the origin.
      Whenever I import DWG's I always make a copy of the DWG first and move all the stuff to the origin and purge the file before I import it to SU.
