EXTERIOR RENDERING....
  • EXTERIOR RENDERING....
    Hi everyone,
    This is my first time post and my first tryout...I started using sketchup due to eagerness to learn 3d application. And I found that it is very useful. Now, my concern is about the application of VRAY to SU. I'm totally blank about this software. Even in sketchup my knowledge is just for a novice...However, I'm very interested to explore my knowledge and to join in this forum for whatever improvement I can be learned from those masters...
    My problem is, I tried to render my sketchup model thru VRAY but the result was can't captured all the view of my perspective. I need your advise how to set properly the VRAY rendering settings. I tried several times but the results are the same.
    Your comments and suggestion are all welcome.
    Thanks.
    shadow0519
    ....another problem guys, I would like to attach image for you to view my model but I can't find the option here....I clicked the insert image and after that there's no more instruction ......someone help there.
    Re: EXTERIOR RENDERING....
    http://forum.asgvis.com/index.php?topic=2043.0
      Thanks Thom,
      I'm currently using sketchup 6 & vray 1.0..
      How to attach image in this forum?
      Thanks again
        here are the links of my works to correct.
        Thanks.
        http://s669.photobucket.com/albums/v...ORKSTATION.jpg
        http://s669.photobucket.com/albums/v...E-w_shadow.jpg
          Anyone help from masters here about my post?
          Thanks.
            I'm not a master! And I work whith Rhino...
            Did you try read the Manual?
            http://forum.asgvis.com/index.php?to...20975#msg20975
            Works for me when I read the Manual Vray for Rhino
