Question about "White Corrected 3" setting from the download section.
  • Question about "White Corrected 3" setting from the download section.
    The settings file "White Corrected 3" produces some beautiful results, beautiful sun and shadows, etc...BUT...this setting style does not "recognize" rectangular lights...anytime I try and place one, it doesn't light, the effects don't produce.
    I'm not sure if anyone is familiar with "white corrected" or knows if it is possible for a render visopt setting to cancel out rectangular light effects....
    Re: Question about "White Corrected 3" setting from the download section.
    Well what's most likely the case is that the Physical camera is enabled, in which you'll have to disable it and then sort out the extreme brightness of the V-Ray sun.
    The other option is that lights are simply disabled....you can enable them in the Global Switches rollout.
