Saving V-ray materials to a skp drawing?
  • Saving V-ray materials to a skp drawing?
    Right now i am using V-ray a lot for rendering all my different designs, but when i save these files and start them later all the materials i added to the sketchup materials are gone. Only the sketchup materials are active. So if i start rendering all the materials are back to the sketchup ones.
    Is there a way to save the files with the materials. A way to link all the materials to the sketchup materials. I am getting tired of adding all the materials to the same design. (i am getting better at it, by practising a lot!)
    Dutch tutorials for Sketchup and V-ray: Proseduction.nl<br /><br />And although i have some tutorials i still am learning!
    Re: Saving V-ray materials to a skp drawing?
    It's a known bug. When you modify a V-Ray material make sure you open up the Options window before you save - otherwise you loose all material changes.
      You can save your settings and materials in a SU template file which saves time if you use common materials in your projects i.e. glass, grass, chrome etc.
      see
      http://forum.asgvis.com/index.php?topic=4997.0
      David
      Sketchup 2015
      Vray version 2.00
      www.davidcauldwell.co.uk
        Just an update on this thread ( as the original link has been deleted - it was an old ASGVIS link)
        To save materials with their VISMATs
        All you have to do is, in SU, create a template file (my template also has common components, views etc) and in that file create all your commonly used materials, glass, grass, chrome, various shades and glossiness of white (!) etc. and then save the file as a template.
        When creating a new model, if you start with this template file, then your favourite materials with their VISMATS are already there.
        David
        Sketchup 2015
        Vray version 2.00
          you can also save out the various materials as skm files to a folder, and then set that folder to be a material library
          Devin Kendig
          Developer
          Chaos Group
            be aware though, any bitmap textures that are used, aside from the diffuse texture that is shown in the viewport, will not be included in the skm file! So be careful.
            Devin Kendig
            Developer
            Chaos Group
