Blue Material
  • #16
    Re: Blue Material
    Originally posted by thomthom
    I think it might be a bug. I've had this problem with transparent material as well. Some times a blue colour appear while it shouldn't.
    It happened to me also once. Even that i applied the material to both sides of the face.
    I think it's a bug.
    www.Top3Dstudio.com
    SU 8
    VfS 1.48.89
    Win 7 64-bit
    • #17
      Re: Blue Material
      Joe,
      Check your PM inbox.
      Regards,
      Jackson
      SU 2018 + VfSU 4.0
      • #18
        Re: Blue Material
        did u try reversing the face?
        • #19
          Re: Blue Material
          this happend to me too! and i just reversed the face of the glass...because it was in the purple face, not the black one....
          that works for me :^)
          • #20
            Re: Blue Material
            I'm pretty sure I've had this even though BOTH sides had the transparent material applied.
            • #21
              Re: Blue Material
              Jackson, there is nothing in the PM.
              Still no luck with it, I reverted back to using an older model when the doors worked and making changes around the doors, kind of a pain in the butt.
              - Doweth!
              • #22
                Re: Blue Material
                Hmmm, strange. I just sent another PM, a copy of which is showing in my outbox so you should receive it.
                SU 2018 + VfSU 4.0
                • #23
                  I know it's been some time since this was posted but I came across the same issue and found the solution that worked for me. I made the frosted glass just a surface (no volume/thickness). Then, in the V-Ray Asset editor I went to Refraction and selected "Thin-Walled". This seemed to fix the issue. Hope this helps anyone looking for a fix to this problem.
                  Click image for larger version  Name:	Frosted Glass Fix.JPG Views:	0 Size:	55.2 KB ID:	1141104
