Vray takes forever to load
  • Vray takes forever to load
    Hi Guys,
    I have just downloaded the latest demo version of vray to try with sketchup 7.
    When i tried out up my old vray scenes from sketchup 6, and convert them to work with the new version of vray. when i hit the render button it takes about 15-20mins before anything happens and the render box to appear.
    I know with the latest version of vray all the materials are automatically linked to the material editor?? could this be the problem.
    although I have completely purged all my materials in both sketchup and the material editor, and have tried the remove C-G materials plugin.
    I have a quadcore with 4Gb of ram so my machine shouldnt be a problem, with sketchup 6 and the older version of vray the render box would come up almost imediately.
    Or is there just a problem with converting older scenes??
    Not sure if anybody elese has found the same problem.
    Thank you very much.
    Will
    Re: Vray takes forever to load
    How big is the model? How much of the file size is geometry as opposed to maps?
    SU 2018 + VfSU 4.0
      The file size is a small model buts its 80Mb.
      but when i used to run it with the older version of vray and sketchup, it used to start the render process almost immediately.
      it also takes time when i run my smaller older files about 20Mb. its so frustrating i am hoping, that its just a problem with converting older versions, and that when i work on one from scratch i dont have the same problem.
      with the older version my machine could handle files up to 150Mb
      Weird!
        Hi Will - good to see you back.
        It is a while now since the new version of vray was launched, but if I remember rightly it does take quite a bit longer to sort out its parsing (or something) before you actually see anything happening. However, overall it seems just as fast as it ever was - certainly with new projects.
        David
        Sketchup 2015
        Vray version 2.00
        www.davidcauldwell.co.uk
          Haha love the motion blur on the guy in the wheelchair...zoooooom!
